cRIO 9022 date setting
Hello!
I would like to configure cRIO 9022, as first step I need to set the date on it because now it's about 1960 :), can you give me a hint where to start with it? I don't have the hardware with me now, it's a part of a project. What kind of toolboxes do I need, is there any written tutorial? Thank you for your help in advance!
(2,815 Views)
You should do the setup and all related things in MAX - once you connected the cRIO to your (local) network…
All that is described in the manual that comes with your cRIO!
(2,809 Views)
