cRIO 9025- FPGA - Not able to access c-series modules integrated with chassis
I am using NI cRIO 9025 module. I have conncected the chassis with few cSERIES channels for voltage and current sensing.
When I tried to configure, I am getting the following error
Access denied: This target is running a version of LabVIEW Real-Time that is different than the Real-Time Module software on the host computer. You can verify the version and reinstall the Real-Time software using Measurement & Automation Explorer.
I tried to use Add/Remove option from MAX. But I am not able to update the real time software on cRIO
I am using Labview 12.0 on host computer and on target cRIO9025 - 11.0.1 version real time is installed.
Please kindly help to update the software on target module.
Ravi Kishore
Message 1 of 1
(2,530 Views)
