cRIO-9030 stuck in Install Mode after RAD
Hi all. I have a cRIO with legacy software, drivers and RTOS from 2016. For record-keeping I attempted to image it using the RAD Utility per an older manual. The image extracted successfully but I cannot for the life of me get the thing out of Install Mode. Manual resets, power cycles, etc simply boot it back up into install mode. The cRIO is a legacy dev machine we keep around to help troubleshoot some support cases so it would be nice to get it back in operation!
(815 Views)
Hi samoa683,
When exactly does the machine get stuck in install mode?
What is the sequence of events / actions you take?
Best regards
Leonard
(750 Views)
