cRIO 9035 : AO-9263
Dear community
We are trying to initially configure NIcRIO 9035 with NI PXIe -1071. We are unable to find the sub-ports (eg. AO NI 9263)  in our NI MAX files. Kindly help us with the procedure. Attached is the screenshot of the config.
Thanking you
(921 Views)
Hi Krishna_9542
I have found an article which will help you to solve the issue. Try to go through that article I have linked.
Regards)
_______
Best way to thank is to give Kudos / Mark as a solution.
(798 Views)
