cRIO 9035
Hi  !
   it is the first time i program CRIO9035 with sub cards ,as the help RT system from NI web, i could find sub cards,and add "Thermocouple continuous input ",in project
   i want to ask how to add channel name ?  it is not on line now, is this the reason?
   thank you very much !
(1,540 Views)
Accepted by topic author xiaoxu0411
cRIO-9035 does not support DAQmx Real-Time mode. You can either use Scan Mode or FPGA Mode. See section II or III of Take Your First Measurement in LabVIEW Real-Time (Data Logging).
https://tmesystems.net/
(1,507 Views)
