cRIO-9047 Error-201003
I have a cRIO-9047 that has been operating without issues for a year, but yesterday, all DAQmx Create Virtual Channel VIs reported a -201003 error. Additionally, MAX lists all the modules in the remote system as having a status code of 88705. If a module is removed, MAX indicates that it is not present, and when it's reinstalled, the module is shown as present. Any information regarding this problem would be helpful.
(367 Views)
Can you include a screenshot of what you're seeing? I was able to set up a project with those devices without error, but I don't have the actual hardware. Also a screenshot of the versions of software you have installed could be helpful (in MAX under software) in case there's some version compatibility issue.
(350 Views)
I am not at the facility where the system is located now, but I can still provide this information.
From LabView Version 2022 Q3 (32-bit).
From MAX Version 2022 Q3 checking the status of an NI-9252 c-Module
(332 Views)
