cRIO 9075: Programmatically set date & time
I'm using the cRIO 9075 (in hybrid mode, if that matters). The RT Host-Vi is started and interacted with on a PC. I'd like to set the date and time of the cRIO to the same time of the Host-PC. How can I do this?
I found this article: http://zone.ni.com/reference/en-XX/help/370622J-01/lvrtvihelp/rt_set_date_and_time/
But this is works with the LV2011 RT-Module. Im running LV2015 and when I try it this way, I loose the connection to the RT System.
The problem is, that the whole system is shutdown regularly so all experiment data start on 01-01-1970. The workaround is to set the time wie Ni MAX eveytime, but this is not convenient.
Greetings
AF87
(3,866 Views)
Have you looked at the System Configuration API under the Real-time palette? There are functions there to both set the Time Zone of your controller as well as the current date and time. This is there from LV2012 onwards; I have ben using this with LV2016 successfully without any unusual disconnects etc.
(3,819 Views)
