cRIO-9081 Module Serial Numbers
Is there a way for the FPGA in the cRIO-9081 to read the serial number, calibration date of the NI-9201 module that is installed in the cRIO?
I would like to get that information and pass it to my Host.vi because we have a requirement to document instrument information during a test run.
Paul
(4,190 Views)
Accepted by topic author Paul_Knight_Lockheed_Mart
Use a property node of the module to read the SerialNumber/VendorId... but the calibration date isn't stored. (example FPGA code shows NI9205 data)
Here a Target-Host DMA Fifo is used to send the data to the RT Controller...
(4,147 Views)
That will work.
Paul
(4,141 Views)
