cRIO 9802 Error 65000
Hi all,
i tried the LabVIEW example "NI 9802 RT Access (Host)", with which i want to mount one SD card. I everytime get the attached error message. I already used chkdsk to correct the SD card and there are no errors on it. It's no problem to write file from the FPGA, but to mount from RT result's in this error.
I use LabVIEW 8.6. NI RIO 3.0.1 is installed on the cRIO.
Can someone guide me to a solution.
Thanks.
Alex
Message Edited by -_ALEX_- on 02-06-2009 10:02 AM
(3,872 Views)
Accepted by topic author -_ALEX_-
Hi again,
i switched back to NI RIO 3.0 and can run the example without problems.
Alex
(3,862 Views)
Alex--
       There was an issue with NI-RIO 3.0.1 that prevented mounting from RT with that error. The problem was fixed in the next version, 3.1. which will be released VERY soon.  I'll reply back to this thread for you once we've got it up on the web.
John
(3,830 Views)
Alex-
     Just so you know, NI-RIO 3.1 is released and available for download.
      If anyone else is running into this issue with 3.0.1, the NI recommended solution is to upgrade your driver.
John
(3,794 Views)
Hi John,
thanks for letting me know that the new NI Rio is available.
I installed the new driver, but unfortunately a got a new Problem. It is possible to Mount and Unmount the SD Card, but i can’t ftp to it.
I tried to connect via Microsoft IE, and received following message:
Does anybody have an idea why?
Message Edited by -_ALEX_- on 02-20-2009 11:13 AM
(3,749 Views)
Alex-
       I haven't seen anything like that before.  FTP should be possible regardless of the software.  You should be able to FTP to the controller even from safe mode. You could format the controller and make sure you have all of the software needed and it's not corrupt, then check again.
       I would first look elsewhere, with software upgrades and new application signatures, it's possible that your firewall is preventing communication.  I think standard troubleshooting should resolve the issue.  Let usknow.
-John
(3,712 Views)
Hallo John,
it is possible to ftp to the controller. There is no Problem on that. The Problem occurs when i try the connect to the SD Card after mounting it in the RT.
I get a Drive Letter (U:), but if i try to connect, i got the error message.
With NI RIO 3.0.0 it worked fine, so i think the firewall is not the problem. What you mean with standard troubleshooting?
(3,689 Views)
