I am using 3x 9233 and 1x 9237 synchronized, and stream the data to 2x 9802. However, when I put the DAQ and 9802 save file diagrams together, the FPGA program hanges at the 9802 open file.
I am putting error out to each of the 9802 file open node, but non of them changes from the default value. While the error out of the DSA settings are properly set to no-error after run.
Is it possible the exporting 12.8M clock interferences with 9802?
