cRIO Fails to Load Shared Library
All,
I'm getting an odd error every other time I tried to load my code onto a cRIO in the dev environment.
Deploying NI_AALPro.lvlib:Linear Fit (LS).viNI_AALPro.lvlib:Linear Fit (LS).vi loaded with errors on the target and was closed.
LabVIEW:  Failed to load shared library lvanlys.*:LinFit_head:C on RT target device.
This VI works the first time, and then fails to run the second time you hit run.
If I reboot the device this corrects the problem, but I have to say this bug costs me quite a lot of time.
Ken
(3,787 Views)
(3,764 Views)
Whoa, that's weird. I do have a rather large collection of VIs, but that's really odd.
(3,753 Views)
xkenneth,
Did that solve your problem? If so, is it reproducible with a small project?
Verne D. // Software R&D // National Instruments
(3,737 Views)
Did that help?
(3,720 Views)
