cRIO Front Panel Server
Dear LabVIEW community.
I have been developing an application on a cRIO-9074 that needs configurations to run. To do this, I have developed a second LabVIEW application to run on a local computer connected on the same network as the cRIO, that writes those configurations on shared variables by using Open/Write/Close API.
Is there any easy way to remote share the Front Panel VI that needs to be configured on the cRIO via web browser to do the same thing? It would be great to have the same display in order to make changes and see see the results.
Best regards.
(3,171 Views)
Hi Quintino,
You can take a look at the following documentation:
Configuring Remote Front Panels on a Real-Time Target
How Can I Use Remote Front Panels With LabVIEW Executables?
Valentin
Certified LabVIEW Architect
Certified TestStand Architect
Certified LabWindowsCVI Developer
National Instruments France
(3,124 Views)
