cRIO Gateway Address cannot be set properly
Apparently setting the cRIO Gateway to 0.0.0.0 causes the VxWorks OS to barf.  Unfortunately MAX will not allow you to set it as a empty string which apparently is the correct and only setting
for things to work if you do not use the Gateway facilities (which most application do not).  If you use the Reset IP DIP SW then it will default to DCHP and if you are connected to a network PC you will receive a new IP as well as a Gateway address of 0.0.0.0  Does anyone understand this conundrum?
(4,060 Views)
Hello Sachsm,
What is the model number of your cRIO controller? What version of OS are you running? Can you turn on the "Console Out" dip switch and attach the report? Also what exactly happens when the RT controller "barfs"?
Kareem W.
Web Product Manager
(4,040 Views)
I am also suffering from gremlins in the networking config.
So far this week i have managed to prevent the system from networking at all, and now it seems to have alzheimers. That is to say, it forgets about the gateway and dns you just told it about.
I am also suffering from the inability to set 0.0.0.0.
cRIO 9023 with RIO 3.6.0
(4,010 Views)
The workaround for now is to set the Gateway to the address of your host pc.
(4,008 Views)
Not gonna help when deployed though.
Smiley Happy
(4,005 Views)
It works for me and I do not always have a PC based HMI connected on
The cRIO network.
(4,000 Views)
