cRIO IMAQ: Writing time images to string then to JSON
TCP Write.vi has an output bytes written. Is it writing the correct number of bytes? You could also do a wireshark capture to make sure everything is being written correctly. If it is, then the problem is your python code is not reading the correct amount of data.
-Jordan
Message 21 of 27
(1,334 Views)
So I added a base encoder and now I'm able to send about 6/10 of the images (within the JSON) to the Python server
Message 22 of 27
(1,333 Views)
Just checked and my bytes written output in LabVIEW is the same value as my data_len in Python
What's a wireshark capture?
Message 23 of 27
(1,332 Views)
Wireshark is an opensource tool that lets you monitor Ethernet traffic. You can install it for free from here. Basically you start a capture that will let you see all the TCP packets being sent over your network. So what did you change with the base encoder?
-Jordan
Message 24 of 27
(1,319 Views)
-Jordan
I thought the issue might be unpacking the serialized binary, but it doesn't appear to be the case
Message 25 of 27
(1,315 Views)
So I've tried running the program with Wireshark several times now. Every time I hit capture Wireshark crashes and now I am beginning to get an error in LabVIEW:
EthernetEthernet
Follow TCP StreamFollow TCP Stream
LabVIEW ErrorLabVIEW Error
Message 26 of 27
(1,305 Views)
I got it working! I had to add a delay in between the last write and close of the TCP connectionTime delay.png
Message 27 of 27
(1,300 Views)
