cRIO USB Support software drivers
Hi everybody,
I'm working on a cRIO 9012 with a NI-9215 module on LabVIEW 2012 (evaluation version). The cRIO 9012 disposes of an USB port on which I put a stick.
I want to put data on my stick, I made a VI and use the path u:\texte.txt where "texte.txt" is already created in the USB stick.
I found in ni topics that I have to install "USB Support" software, I tried to add it on my RT target but it is not present in softwares' three. I get only "UBS passport", you can see it in attached picture.
I suppose that drivers/softwares are avaible but I don't find its. Somebody could get me out of this ?
Thanks.
Ximusma
(3,463 Views)
Hello Ximusma,
Did you alreay see this KB?
Be sure to use the correct drive letter
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
(3,418 Views)
