cRIO device: Error connecting to GPIB driver or device. The NI-488.2 driver may not be installed.
I am using a cRIO 9039 (sync) device. I was provided an vi (attached) to check my system as well as my cRIO infor. However when I run it, this following error appears:
LabVIEW: Error connecting to GPIB driver or device. The NI-488.2 driver may not be installed.
Motion: No error.
NI SoftMotion: No error.
Error connecting to driver or device. The NI-488.2 driver may not be installed.
VISA: (Hex 0x0) Operation completed successfully.
Only System Infor displays information but Chassis does not.
I already install the cRIO drivers, NI-488.2 driver, Labview FPGA.
I greatly appreciate your help.
(2,922 Views)
Hello levan8421
Could you attach a MAX tech Report of your cRIO? It seems you downloaded the software but didn't add it to the cRIO.
(2,881 Views)
