05-09-2008 12:35 AM
05-09-2008 08:20 AM
raviece,
Are you connecting directly to the cRIO controller from your PC? If so, you need to use an ethernet crossover cable. If you connect through some kind of switch or hub, you use normal ethernet cables
When you connect directly to a controller from your PC (no netwoking device) then you also must setup your PC with a static IP address. Take a look at this KB for more details: http://digital.ni.com/public.nsf/allkb/72AE8CADA1AF075686256A16005D55B1
05-10-2008 12:04 AM
05-10-2008 12:22 AM
