cRIO logging voltage / frequency
Dear all,
I want to use a cRIO to record an analog sine wave over the course of months. Finally, I want to get the frequency of the signal, which I could do in post-processing, but logging the already calculated frequency would be nice as well.
My approach is to simply program my cRIO (FPGA) so that the raw voltage values are write directly to a USB harddrive.
However, that way I cannot access the data after lets say every week without disconnecting the harddrive.
Can someone give a hint on an alternative approach?
Maybe take a small PC, connect it with the cRIO via a crosscalbe and make the PC stream the data in blocks to a harddrive? Thanks for any advice.
Cheers, Jack
(3,229 Views)
Can you connect to cRIO from MAX (PC)? If yes, select "file transfer" from context menu and download file without disconnect harddrive
(3,214 Views)
I would also recommend using a seperate PC for logging the data.  That PC can have network access for allowing the data to be on the network if you want.
(3,211 Views)
