cRIO on hybrid mode: either scan or fpga can work
no errors, it can run normally, only can't get the scan data
Message 11 of 15
(1,352 Views)
What value comes out of the "CTR0 2" terminal that's hooked up to the "CTR0" call in your real-time VI? Also, do you have error enabled on your VI so that you could see errors if they did show up?
Colden
Message 12 of 15
(1,333 Views)
No error show out of the terminal CTR0, I can run the program for all function working well but only the CTR0 always got "0" and doesn't receive any data. Thanks
Message 13 of 15
(1,328 Views)
Also, I have drag out one more CTR0 in another loop to run, it also doesn't work. And the "CTR0 2" also output "0". Error enabled. Thanks
Message 14 of 15
(1,326 Views)
If you run your VI with highlight execution, does it show a "zero" moving from the CTR0 output going into the "CTR0 2" indicator? Also, do you have a verification that your counter is receiving a pulsing signal that would cause it to output a non-zero output?
Colden
Message 15 of 15
(1,315 Views)
