cRIO output large waveform
I have cRIO with DA converter and I need to output digitalized data. The problem is, it is too large to send the whole waveform to the fpga at once. So I am thinking about synchronizing it with the host and periodicaly send only parts. Does anyone have a better solution or advice about this matter?
(3,275 Views)
Hi Seky,
               I agree that this is pretty much the only thing you can do - splitting it in smaller parts. Try using the DMA FIFOs for the data transfer.
                    https://www.ni.com/docs/en-US/bundle/labview-fpga-module/page/how-dma-transfers-work-fpga-module.htm...
                    https://www.ni.com/docs/en-US/bundle/labview-fpga-module/page/avoiding-buffer-errors-in-dma-applicat...
Denis
(3,242 Views)
