Hi community!
I'm using LabView 2020 and OPC Ua toolkit 2020, I want to use the cRIO9054 as my write client, the problem is that when I try to run the VI appears the following message
I already go to NI MAX and check the software on my cRIO but the NI OPC UA API doesn't appear on MAX to install it on my cRIO, it only appears the following software
Anyone knows how to solve it?
Additional I have the following software installed on my cRIO:
