cRIO simple signal retransmitter
EDIT: NEVERMIND....I FOUND THE PROBLEM---Loose wires out of the AO card....DOH!!!
I am building a simple signal conditioner demonstration for a customer and have created the following code on a 9076 chassis. I can see the output changing correctly when I am using the RT Host interface that I wrote to troubleshoot; however, the analog output card is not updating at all and stays at 0V. Is there something special I should be doing?
The FXP conversions are to allow me some extra bit width to scale the input from Mod3 which is a 9237 and I am transmitting out a 9263 card. The loop are can be varied and I have tried values from 1 - 10 usec. Right now I am compiling the code to be able to see if any errors are present on the AO node.
Any ideas? I am feeling pretty dumb.
Drew
Message 1 of 1
(2,318 Views)
