cRIO - storing calibration and setup data for the machine control
I am using 9022 for the industrial machine control. How can I store some limited data for calibration constats and setup parameters so LV RT load these at power on? I think that preferred lace to store this data would be cRIO controller. I did some searching but nothing relevant yet.
Arthur
(2,525 Views)
You can store it in as file in a folder at the cRIO as if you would do it on a Windows computer. Then at the start of your application you read the parameters from the file and write it to the regarding Nodes/Objects.
Christian
(2,509 Views)
