cRIO
Hi :
I am doing some cRIO project, the procedure is like this:
By creating a project communicate with cRIo monitor systems. The code has been created to caculate the data package and send as shared variable.
The shared variable connect with datasocket write (same proejct), I try to directly using the Matrikon OPC . so i write the URL like:
opc://130.88.8.227/Matrikon.OPC.Simulation.1/Bucket Brigade.Real4  , it is said error .
I already try to use simple OPC write and OPC read in the same computer which  URL change the IP address to Localhost, it is working, but when i change it to the IP 130.88.8.227. It just not working.  The Vi was in the attachment.
 So the question are listed below:
1. Apart from basic modules based on the cRIo platform, did i need to install other module to support the process, for example DSC module.
2. Is it  because of Port configuration or other problems
3. If i decide to change to the NI server, How can i achieve my aim?
Kind regard
Zhang MIn
thank you very much
Zhang Min
Message 1 of 1
(2,560 Views)
