cRIO
hi every body, i have developed a code for power quality analysis to aquire samples at rate of 50kS/s in FPGA using cRIO-9067. the code is successfully executed and the graph are plotted successfully in the real time processor vi. i want to save the samples in my computer for future reference but i was unable to save them in my pc.  anybody please help me, how to save the sampled data in my computer from the rt-vi
(4,077 Views)
Accepted by topic author jagadeshwar
You should have another application on your PC for saving the data.  You can use a Network Stream or a TCP/IP connection to send the data from the cRIO to the PC.
(4,055 Views)
in my fpga project my user interface vi is in my computer. i want to run may rt vi from the user interface vi and i am unable to do so. when i run my user interface vi in host computer the rt vi shoud start automatically as a background process. help me please
(3,965 Views)
No.  You deploy to the RT first.  Then your PC application (GUI) can connect to the cRIO.  Treat the RT as a seperate computer that should run a specfic application as soon as it is powered up and always runs until it looses power.
(3,951 Views)
