cRIO9053 without access
Hello everyone
I have a little problem with one of my cRIO. I have the connection with the cRIO ok, the RT and the webserver it's ok like we can see in the image below.
When i go to MAX the cRIO appears disconnected:
When i try to connect via webserver, i can connect to it, but i can't get the configurations (only IP and DNS) and when i go to webDAV it causes the following error:
The only way i can find to get the files and explore the cRIO it's by adding a network connection in the folders from my PC and explore via windows explorer.
Any idea why this behaviour? Any idea to fix it?
Thanks in advance!
André Simões
Work with LV2019 and cRIO since 2021
Message 1 of 1
(1,375 Views)
