calculate 1/e^2 of beam intensity profile Measurement
I have a beam intensity profile data (Gaussian Beam) . I want to calculate 1/e^2 value. From that value want to calculate the beam diameter.
Please need a help. Looking for quick solution.
Message 1 of 12
(5,714 Views)
1/e^2 is a constant and independent of any data.
There are old discussions showing how to fit 2D gaussian data to get parameters. Can you attach your code and some typical data?
Message 2 of 12
(5,679 Views)
Here, is a VI. Which is produced Beam profile using XY graph and image averaging.
I saw that post but i din't get it.
You can load the image and will generate XY graph which is located all the way down.
Message 3 of 12
(5,670 Views)
I am sure you could have cropped that image to the interesting part (a few percent of the pixels), right? Fitting millions of background pixels is not useful and very expensive.
Which post (link!) and what part didn't you "get"?
 An image can be represented by a 2D array in an intensity graph. A XY graph is not suitable for image data. I don't have IMAQ and I don't need it for this.
Message 4 of 12
(5,659 Views)
Yes, you are right. Do you have any idea how can I remove the background?
and what about the calculation of 1/e^2 measurement?
Message 5 of 12
(5,656 Views)
I didn't get it about gussian fit model and how can I used it over here.
I
Message 6 of 12
(5,654 Views)
You still have not explained what that means.
You can calculate 1/e^2 with any calculator (= 0.13533) and that's not very interesting.
I am sure you have something else in mind. Please be specific.
Message 7 of 12
(5,651 Views)
You can use any image editing software to crop the image around the interesting part (position is irrelevant because you seem to only be interested in the size) and attach it. Should be a very small file.
Is the background zero or is there an offset? If there is an offset, leave sufficient background (e.g. twice the size of the spot) to be able to reliably fit for the offset.
Message 8 of 12
(5,649 Views)
Start here.
2DGaussFit
What part is not clear to you?
A zip file with the code, the model, and a sample image is here. Should run out-of-the-box. All you need to do is get the width in your desired units.
Message 9 of 12
(5,647 Views)
Here,I have attached the image. That's what I want mean.
Message 10 of 12
(5,638 Views)
