calculating equally spaced values over a range
Any help would be really appreciated,
I've bee asked: Calculate Range for a sequence of 101 equally-spaced angles in the range from -90 to +90.
Basically I need 101 values equally spaced between -90 and 90 each of these values needs inserted into a range formula and graph.
This is the vi im working on, the unassigned T input variables on my forumula nodes are the angle values I need to calculate.
(2,950 Views)
Use the Sawtooth Waveform function generator with the proper inputs.  Or use a FOR loop with appropriate math on the iteration terminal.  Both are simple and quick.
(2,927 Views)
Or use the Ramp Pattern function to create a 1D array of equally distributed values between two limits (-90 and 90).
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(2,921 Views)
