calculating offset
Hallo,
how can I calculate the offset of two functions?
(Details: I have two 1D-arrays Y[1,...,N] and Z[1,...,N] with the N values of the two functions. I want to substract them from each other in a way that a part of the function is eliminated. My idea is the following:
sub[1,...,N]=0
for k=1 to N
for i=k to k+m (only the part [1,...,m] of Y is interesting to me and the offset i of Z)
if i<=N then sub[i]=Y[k]-Z[i] else sub[i]=0
next i
next k
I save each substration-array and select the one with the lowest sum. That index j should be the required offset.)
Note that my idea isn't programmed in LabVIEW yet, perhaps one of you has a better idea.
Arno
PS: If you attach a VI: I use LabVIEW 6.1, so please it in a way I can read it.
(3,804 Views)
iam sorry i coud not understand what you wanted ,are you looking for a VI which takes in 2 1D arrays and subtracts one another with a given offset.
plz explain it.
(3,804 Views)
Hallo,
sorry for writing to complicated. Details:
I have two 1D-arrays. I want to substract one from the other. That's easy, if they don't have an offset. How can I calculate an existing one? As soon I have it, my problem is solved:
use the offset (x[i] -> x[i+offset]) and substract (y[i]-x[i+offset])
Example: First array: 1000 values of the sin x-function. Second array: 1000 values of the sin(x+1)-function. How can I calculate the "1"? Note: My function is NOT sin, and I do not know an analytic formula for it.
Perhaps now I am clearer.
Arno
(3,804 Views)
You have to compute the cross-correlation of the two vectors and the maximum will be you offset
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(3,804 Views)
Doc-Doc
(3,804 Views)
