calculating pixel intensity in a black and white image
Accepted by topic author iskourke
I forgot that the Boolean to 1:0 conversion uses I16 as its output representation. So if the sum is greater than 32768, the I16 will roll over. I32 can go to 2^31. U64 will probably allow you to sum all the pixels in a movie.  Put a conversion bullet following the Boolean to 1:0.
Lynn
Message 11 of 12
(1,017 Views)
Yes! It worked! Thank you both, thank you very much! Kudos for all.
Message 12 of 12
(995 Views)
