calculating time delay between two signals aquired from DAQ
Either my memory of the function is wrong or it changed at some point. The time returned is actually the number of seconds since 1904. The t0 of the simulated waveform is actually 0 so that accounts for the high delta. You can modify the function to not add t0, make the t0 the same for both waveforms, or use the Index option and calculate the time from that and the dt.
Message 21 of 22
(1,315 Views)
I am having a problem with the basic level trigger detection, the time delay between the two is always zero. Both triggers are within in a loop so I'm not sure why the time delay is always 0.
My VI is attached.
Prince Dhaliwal
Message 22 of 22
(1,115 Views)
