calender
Gerd  the timestamp datatype was introduced in LabVIEW 7.0 You need to do it the hard way
Message 11 of 15
(1,163 Views)
Hi Jeff,
in message #6, #8 and #10 I was explicitely talking about "usual" numeric controls…
Message 12 of 15
(1,158 Views)
yes it is hard  since time stamp feature is not available in labview 6.1
so is their any other way to create a calender to make it a easy task?
Message 13 of 15
(1,151 Views)
In versions prior to the timestamp datatype the timestamp format specifiers won't exist either.   (Sorry Gerd- I had to run off to a meeting and left you with only the bare clue)
By "The hard way" I truely mean you WILL need to depend on building your calander off the elements in a date-time- record cluster.  (or a completely new structure of your own devising)
Message 14 of 15
(1,142 Views)
In pre-timestamp versions of LabVIEW I used to use an active x calendar control.  A quick google will find you a selection.
MC
Message 15 of 15
(1,121 Views)
