calibration DAQ assistant
I'm trying to calibrate a LBS200 Futek load cell using the DAQ assistantin LabView 2016. However, once selected Acquire Signals-> Analog Input->Voltage  and selected the connected channel (ai0), the DAQ assistant display only settings and not calibration. How do I solve this?
(2,362 Views)
HI Fede,
what kind of "calibration" do you want to apply?
What are the steps ypu want to take?
Are you talking about a custom scale, that you want to apply on your voltage signal?
(2,355 Views)
Hi GerdW,
yes, indeed I would like to apply a custom scale, registering multiple voltages while applying known loads.
(2,352 Views)
Hi Fede,
@Fede2020 wrote:
Hi GerdW,
Then (mostly) all you need is written here.
Create a scale, then apply it to your voltage channel when calling CreateVirtualChannel…
(2,326 Views)
