Hi everyone, I have recently been using labview for an exam and am having difficulty interfacing with a calibrator (ugeng 9133) that does not have a command set compliant with the SCPI standard.
I have two questions that I am facing.
Having to perform a calibration, I need to carry out more measurements by varying the instrument set point in its calibration range, is there a way to make this operation automatic? ie without having to manually change the set point each time?
The second question is to identify a criterion to ensure that the set point is reached, I thought as a criterion to consider that the set point is reached only when the last 5 set point and temperature measurements coincide, how could this condition be set on labview?
Thanks in advance to anyone who knows how to help me or who knows how to direct me on what I should do.
I am attaching one of the scripts that I made about it.
