call LabVIEW DLL in Java (JNI)
I would like to know how to call LabVIEW DLL in Java (JNI).
I have searched in the forum and some mentioned that I need to have a wrapper DLL that exports the "JNI-style" names and calls the names exported from the LV-built DLL. I do not know what does this means??
I want to use JNI to control GPIB so I want to build 488.2 or VISA vis into DLL which I can call in JNI. Could anyone guide me in doing this?? What are the steps and how to do it??
JNI and LabVIEW
Thank you & Regards
Lee
(5,560 Views)
More things to add...
I have found websites that mention that I need to have a header which is generated by JNI to be included in the LabVIEW DLL header so that JNI can use this LabVIEW DLL in JNI. How do I do that??
Both links below have information on calling DLL in Java (JNI).
Calling Native C/C++ code (in a DLL) from Java using JNI
Java Native Interface: Programmer's Guide and Specification
I am using LabVIEW 8.20 and found that I could not add in external header when building DLL in DLL properties. I can only add additional LabVIEW headers but not other external headers. Does that mean that I need to build the JNI header and call it in my vi before I build this vi into DLL to include JNI header in my DLL header?? Could anyone advise me on this??
Thank you & Regards
Lee
(5,553 Views)
I don't have particular information about how to make calls from Java to LV DLL, but I'll describe
you how to make a wrapper DLL.
So, beside the LV DLL, you'll need another DLL that works as an interface to the LV DLL. In this
DLL, you'll have to write a function that matches every function in your LV DLL. I'll give some code
sample in C.
void /*some calling conventions and JNI specific stuff*/ loadLVLib()
    // load the LV library in to memory. The calls are different for each platform (and compiler),
    // but in VC++ for example, this is done with the LoadLibrary() function.
    // This will give you handle to the library
void /*Again some calling convections and JNI stuff is required*/ doDAQOperation()
    // use the handle to make a call to LV function. You can do this with GetProcAddress()
    // in VC++, there's also other means to do this.
void /*JNI etc stuff*/ releaseLVLib()
    // in VC++, one would use FreeLibrary() function in here.
I think this should give you an idea of the wrapper. If you have more questions about this,
post them and I'll try to give you an answer.
(5,541 Views)
