call a text file from Labview program
Is it possible to open a txt file(or pdf file) in labview? I mean the program can still run when a text file or pdf file pops up.
I tried to use "file dialog"--"open file", but the file never pops up. Can you help me on this?
thanks,
bj
Message 1 of 26
(7,571 Views)
Search the palettes for System Exec.vi.  This allows you to run any executable by making a command line call.  I'm guessing that Adobe Reader and Notepad have a simple command line interface to specify which file you wish to open.  In fact, it may be as simple as "c:\windows\notepad.exe c:\temp\blah.txt", where c:\temp\blah.txt is the file you wish to open in Notepad.  Note that I'm guessing on the path to notepad.exe there, I'm not sure where it resides, exactly.
-D
Message 2 of 26
(7,558 Views)
> -D
I'm looking also to open a PDF file.
Darren thnx it works 🙂 🙂 🙂
Veldmous
Message 3 of 26
(7,549 Views)
> -D
Thanks, nice solution!
Just one thing... the program and file sources is static. So when I
have created a link to an external program and auto-open a specified
file, it only works on my own system. When I run my application, in
which this function is integrated, on another system (with other drive
arrangements due to network etc.) I get an error because the (fixed)
specified file paths can't be found!
Message 4 of 26
(7,549 Views)
> -D
Just one thing... the program and file sources are static. So when I
Message 5 of 26
(7,549 Views)
The problem with opening a file with the command line, is that you have to now the location of the program that opens it. It does score points for simplicity.
Another (more complex) way to open any file with it's accociated program it to use ShellExecute.
Wiebe.
Message 6 of 26
(7,542 Views)
wiebe@CARYA schreef:
> Hi,
> Regards,
> Wiebe.
> ShellExecute.vi:
> http://forums.ni.com/attachments/ni/170/169706/1/ShellExecute.vi
will try this option too ...if I find some time...
Message 7 of 26
(7,541 Views)
There is a VI called Open Acrobat Manual in the \help\_browser.llb.
Message 8 of 26
(7,536 Views)
Thanks Dennis.  I knew that VI existed, but when I was answering the post late last night I didn't feel like looking for it, and I figured somebody else would point it out by the time I got to work this morning.  🙂
-D
Message 9 of 26
(7,529 Views)
Here is a vi I created to do this sort of thing. Hope it helps.
Joe.
"NOTHING IS EVER EASY"
Message 10 of 26
(7,521 Views)
