call a vi two times in 2 different subpanel in a vi
thank you titto
how can i call one vi 2 or more then 2 time in the same vi,,,, within subpanel,,,,
in this vi i have a tabpage,, on page 1 i want to open,,, second.vi on subpanel.,,..
and,,, repeat the same thing on the page 2...
i know attached vis r not working,, but,, this will give you idea, wht i m trying to do,,,,
manisha
Message 1 of 11
(4,251 Views)
hi
activate the <reentrant execution> in the VI properties dialog
regards timo
Message 2 of 11
(4,245 Views)
hi timo.. thanks,,
no,,could not make it.. cause,, i m still getting the same reply that vi is in suspended mode,,,
manisha
Message 3 of 11
(4,235 Views)
can anyone,, give the solution for my vi,,,,
i have a tabcontrol on vi called first.vi,,,&,, i want to insert second.vi on both tabpages of first.vi,,, how do i do that,,,
i have attached my vis,, above,,, if anyone could help me,,Smiley Sad
manisha
Message 4 of 11
(4,229 Views)
Make your second VI a template VI (.vit extension).  You will first want to study the VITs in detail -- they have their own idiosyncrasies.  And sub-panels add to the complexity.
-Khalid
Message 5 of 11
(4,225 Views)
thanks,, khalid,, i was eagerly wating,, that,, some one, reply me and,, help me to cum out of this, problem,, thanks, for replying first..
but,, wht is this .vit,., and,, how it works,, i dont have any idea about that,, but,, can you do that ,, thing,, can you pass example ...
thanks,, once agin,,,
manisha
Message 6 of 11
(4,226 Views)
You should load two SubVIs with different names.
So there are two ways.
1. You can make a copy of "second.vi"
2. You can create a template based on "second.vi".
Jack
Win XP
LabVIEW 6.1, 7.0, 7.1, LabWindows/ CVI 7.1
Let us speek Russian 🙂
Message 7 of 11
(4,219 Views)
no, i cant do that, becoz here i have give simple example with only two pages, but,, in my actual program i have to deal with 8 pages,, and 5 different vis... so i can create 5 * 8 = 40 different vis,,
Message 8 of 11
(4,215 Views)
Manisha, I remember your commas and semicolons...  well,,,  good,,;;;  goood..;..;,.,,,
VI templates are "special" type of VIs with the .vit extension.  You need to find documentation on these and read them before trying -- search your manuals, the website, etc.  The truth is out there... somewhere.
As I said, you can save your Second VI as a VIT and it will work -- BUT, you really want to know how the instances of a template VI get instantiated, etc.  It's a different ball game.
-Khalid..,,;;..,;,,"   Smiley Happy
Message 9 of 11
(4,215 Views)
Smiley Happy thanks,, for your comment,,, well,, i m very much confused with this problem,, well ,, as u said,, im trying to understand abt this vi templets,,
though,, if i will not get answer then,, i will come back agin,, with my problem....S...
thanks,,
manisha
Message 10 of 11
(4,212 Views)
