call function node exception AI SingleScan
 Hi all,
 I am running a Labview 6.1 application on Windows 2000.
 When I run the circuit to measure waveform curve on 1 input it works fine.
 But I had to introduce a measurement of 2 more inputs and now get the following exception (this happens sporadically - mainly when you have important measurements):
 "An exception occured within the external code called by a call library node......VI was stopped at Call library function node 0x239C of subVI "AI SingleScan (single-point waveform).vi".
 The call function library calls this routine out of lvdaq.dll with calling convention 'C' (otherwise the program crashed instantly).
 I hope that someone can help me solve it.
 Thnx xris.
(2,906 Views)
Hi Xris,
I would like you to check if the information given in the following thread will solve you problem.
http://forums.ni.com/ni/board/message?board.id=170&message.id=88345&requireLogin=False
If the problem keeps existing please post again in this threas.
Thanks in advance.
Bets regards,
Carsten Sprung
Application Engineer
National Instruments Germany
(2,888 Views)
