call imageprocessing functions
is it possible to call imageprocessing functions from other libraries like OpenCV?
(4,342 Views)
Hi muks,
if you have a dll you can use the "Call Library Function Node", or you can use the "Code Interface Node" if you have c code.
Hope it helps.
Mike
(4,339 Views)
Hi mike,
           I havent used either of them.Can you elaborate a lil bit?
(4,336 Views)
Hi muks,
with the "Call Library Function Node" you can call the exported functions of the selected dll. For example the user32.dll to get the current mouse position. If you have c code you can use the "Code Interface Node".
[link removed; article no longer available]
Mike
(4,332 Views)
Hi, muks,
It was discussed here: Using OpenCV library in LabVIEW.
Use search with OpenCV string - this will give you some links. Smiley Wink
Andrey.
(4,327 Views)
Thanx andrey.Was exactly what i was looking for
(4,306 Views)
