call labview dll to vs2005
Hello all,
I have made a dll using labview that I want to call in an ASP page using VS2005.
I have done some research in the forums and tried some solutions but I still haven’t worked it out.
I made simpler dll (just adds two integers) to try it but still noting.
Can anyone present me with a simple code that calls this simple dll in asp and returns the result?
Thanks in advance,
Adam
(2,601 Views)
What isn't working for you? The only thing you should need to do is create a P/Invoke import for your DLL and then call it from your C#/VB.NET code. If you are using a version of LabVIEW before 8.0, you'll need to worry about the UI thread - here are the details on that. I don't have a simple example, but let me know what version of LV you are using and what is going wrong.
(2,584 Views)
