call library function node- Need help
Hi all,
I have a flow meter to which I have to do interface in LabVIEW. Flowmeter vendor has provided a dll and the function prototype document,
I have not used extensively the call library function node, In function prototype document I have function named -
"extern int GetConnexionStatus(CONNEXION_STATUS*);" how to write the Call library node for this function ?
(5,107 Views)
Use Call Library Function From Connectivity Tools
Then Browse for the Libray Name or Path, You can Specify the Library path Specified by Flowmeter Vendor
Actaully Single Library file has many Functions which you can Browse in the Function Name
@systemcrash wrote:
Hi all,
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(5,104 Views)
Whatever you have written is the procedure to follow which I know, could you pls tell me what "type" to use for the parameter which is inside the bracket for the below function
(5,092 Views)
There should be a document for Refereing the Type of Input and Output data along with the library which you need to refer
(5,075 Views)
No, we can't! The datatype CONNEXION_STATUS is either an enum or a structure. Which of these we can't say without seeing the entire header file for the DLL and/or the documentation manual.
If it would be an enum you should be fine by configuring it as 32 bit integer passed as Pointer to Value. If it is a struct things might get a lot more complicated depending on what elements are inside the struct.
Rolf Kalbermatter  My Blog
(5,066 Views)
Accepted by topic author systemcrash
Hello all,
I used Import shared library wizard after getting ".h" file from the dll developer and was able to complete the required task of communicating to device.
(4,959 Views)
