call picture in picture control with its run time menu
Hi to All,
I m doing one application for Frame grabber using Lab view. I m capturing pictures with
one camera which has its own software. I did the actual interface between that software and Lab View for data acquision.
Now i just want to call the front panel of that software with run time menu in to Lab View. So i will like to know , how it can be done?
Jenilia.d
Canberra
Australia
Jenilia D'souza
(2,433 Views)
All you have to do is create a runtime menu with the particular software name or somthing else for your convience ,then by making you os the system exe.vi you can call that particular software.
Sorry if i have not understood your problem correctly.
cheers
vicky
(2,429 Views)
