call vb dll
Hi there..
I have a comm.dll created from visual basic 6.0.. How do I call it out from VI? I used Call Library Function Node and from the Function Name list down box, I got 4 items which are DllCanUnloadNow, DllGetClassObject, DllRegisterServer, DllUnregisterServer.. After choosing either one of the option, what is my next step should I do? I'm really not familiar with those dll things.. I hope you all can give me a details guide on calling this dll. Thanks in advance.
Regards
Chong
Message 1 of 8
(7,671 Views)
hi there
for COM objects you have to use the automation. on the FP open the controls palette and go to Refnum->Automation Refnum. On the BD use the functions from the Commmunication->ActiveX palette. see attachment. there are some examples using COM and take a look at the LV help files.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 2 of 8
(7,668 Views)
Hi .. thanks for the reply
Please take a look at these 2 pictures.. How can I call the function to show the form2 out? Any advise? Thanks??
Message 3 of 8
(7,666 Views)
Here are links to some documents about VB dlls and function calls using ActiveX:
http://digital.ni.com/public.nsf/websearch/138C65271FC4E2AE86256ED300549751?OpenDocument
http://zone.ni.com/devzone/conceptd.nsf/webmain/C43F8D1DDC1F0E2386256E5C000555F1
http://digital.ni.com/public.nsf/websearch/A51C520CED4FB5F98625707B006CC32F?OpenDocument
http://digital.ni.com/public.nsf/websearch/44E40ACF1644DB77862562990054D672?OpenDocument
http://zone.ni.com/devzone/conceptd.nsf/webmain/7f41004ee990d4da86256a9d0064d522
http://zone.ni.com/devzone/devzoneweb.nsf/Opendoc?openagent&1744411D9B6C5820862567C2006DC236
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
Message 4 of 8
(7,638 Views)
Thanks for the reply. I've already read through all the documentation that you provided but still haven't found a way to call the user form out from the VB dll. Could you please guide me on this? Thanks..
Regards
Chong
Message 5 of 8
(7,628 Views)
I'm afraid I'm not sure what you are asking. The VB code you show is a function call that invokes the form. The LV code shows you opening the class and calling the function...looks like it's doing what you want.
What is it that you want to do exactly?
Message 6 of 8
(7,592 Views)
I want to load the form in NI as though it was in VB. The method that I used (previous jpg attachment) was not successful to call the form out.. May I know is it possible to do so? Thanks
Message 7 of 8
(7,580 Views)
I'm afraid I don't know enough about VB6 forms to be able to say. You should be able to wrap up calls to create forms and access them through LV. You might want to create a new thread in DevZone with that specific question - someone out there probably can help you.
Another option is to move to VB.NET instead. If you create a WinForm control (VB.NET version of Forms), you can actually embed them onto your VI front panel (LV 8.0 and later).
Message 8 of 8
(7,562 Views)
