call vi from main vi
Hi
I build a vi in  labview and I called it 1.vi , then I open new vi and called it 2.vi , then I build main vi , this main contain two bottom  one called " called 1.vi " the another called " called 2.vi "
What I want if I press on bottom " called 1.vi " this bring 1.vi file and appear on screen in main VI  ,, who can I do that
If some one have example I would be very thankful to him
wisam
(2,526 Views)
Hey wisam,
As attachmend you will find a little example, there may (will) be better solutions, it's only a suggestion resulted from clickling a little bit within LabVIEW. It's in 8.2
Christian
(2,518 Views)
