caller name
when you use VI property "Callers" it returns array of caller names. The problem that if you call vi dinamically, this property returns empty array.
So, how can i know name of caller vi, when callee vi is dinamic vi?
(6,651 Views)
Nadav,
the "Callers" property returns the list of all VIs that call the subVI from their diagram. At run-time the "Call Chain" function (Application Control palette) returns the call chain of VIs up to the Top level VI e.g. from which caller the subVI is currently called. That function also works for dynamic calls.
LabVIEW, C'est LabVIEW
(6,651 Views)
Thanks, Jean-Pierre.
But "Call Chain" function returns for dynamic calls only name of sub-vi.
(6,651 Views)
Nadav,
if by dynamic call you mean using "Call by Reference Node" then yes "Call Chain" DOES return the chain of callers up to the Top Level VI. If you use the Run VI method then no "Call Chain" does not return the name of the VI that invoked the method.
When a VI runs Top Level (Run VI method), there is no way to figure how/by whom the VI was run.
(6,651 Views)
Thanks.
(6,651 Views)
OK, so as long as you're operating within the same application instance this is true.  But, if you open a remote application instance and use CBR (Call By Reference), be advised that the called VI immediately becomes top level.  A "Call Chain" function called within that VI will only report one element (itself).
When crossing the application instance boundary (e.g. a VI in an LVPROJ or EXE using CBR to run a VI in another EXE) note that:
Queue references, etc. are managed by top level VIs.  This means that subVIs that create queues can run and then go idle as long as the top level caller doesn't go idle.  When the subVI becomes the top level caller (because it was called by CBR in another application instance), any references it creates are immediately disposed when the subVI goes idle.  Also, USRs (Uninitialized Shift Registers) reinitialize when the managing VI goes idle.  So, while I haven't checked this, watch out for USRs getting reinitialized with the next CBR call when the CBR crosses an application boundary.
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
(6,135 Views)
I can confirm!
I have also seen queues created by a served AE invalidated when the network connection to the the AE drops out even though the app running in the machne is still active. it was subtle but it makes sense.
Ben
(6,090 Views)
