calling Quit LabVIEW function in a callback VI is not working
calling Quit LabVIEW function inside a Callback VI (of an activeX component) is not closing the current instance of LabVIEW.
does anyone else have this issue?
RENN
LV2012SP1 64bit
Kudos always welcome for helpful posts 🙂
(2,748 Views)
Sounds similar to this - https://decibel.ni.com/content/message/48506#48506
The bug is that the Quit LV function does not work when called from a VI launched through Asynchronous Call By Reference
AQ said that that bug was resolved in the 2013 beta, so you could try joining the beta to see if that solution also works for your case.
___________________
Try to take over the world!
(2,745 Views)
