calling VI's through menu
Hey Mike
 Have u seen my uploaded code???
 and i clearly explained the case to jim (last message on page 3) with one sample i've tried .
Message 31 of 34
(737 Views)
Hi Jagan,
yes a saw your code. You shouldn´t insert such a great function into an event case. I think the better way is to create a parallel loop. In this loop you can insert your code. You can communicate between this two loops with for example a queue.
Did you found a solution to upload your vi´s!
Mike
Message 32 of 34
(727 Views)
Mike,
Im not getting u, can u give me a sample for runnning a parallel loop with a queue..
Thanks and Regards,
Jagan
Message 33 of 34
(721 Views)
Hi Mike
Hey i need to select  multiple menu items in the file menu. but now after closing one menu item only im able to open the other,for example even i select the second menu item it will be opening after closing the first menu item i have opened.
Thanks and Regards
Jagan
Message 34 of 34
(691 Views)
