calling an Executable from network computer using VI server.
I need to call an Executable file and need to give values to the control which is present in that exe using VI server.I can perform this operation on the same system which i installed that executable.but while I'm trying to call the same exe from the diffrent system that is not communicating.That is communicating only the vi not EXE.Is there is any way please let me know.
Thanks & Regards,
Naveenkumar
(3,294 Views)
Can you post some code showing how you are setting the controls? When you open the application reference, are you passing it the correct parameters? (Machine name/address and port)
(3,286 Views)
