calling c function that return a string
Hallo,
I found an example for calling void c function(https://forums.ni.com/t5/Example-Code/Calling-a-C-built-DLL-in-LabVIEW-to-Generate-and-Sort-an-Array...). I could adapt the example and make the function return an integer. the code of the adapted function would look like this:
int __declspec(dllexport) multiply(int number)
return number*3;
But I have problems when I want to return a string. Does someone knows how I should do. I tried:
char* __declspec(dllexport) say(int number)
return "hallo";
but won't compile.
(3,415 Views)
I haven't worked with C-connections or dll's much, but technically you're not returning a string, but a character pointer. As such you get the adress where the string starts as an integer. You'll need to typecast the int-adress to a string.
Check your code when running and i'm sure the C-call returns a 32-bit int alot bigger than a normal character.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,401 Views)
davico wrote:
but won't compile.
Are you asking a C question, or a LabVIEW question?  What's the error message?
(3,394 Views)
yes the question was  more a c question then a labview question. I found the solution anyway, the correct code in order to get string is:
_declspec(dllexport) char* testchar2();
      return "hallo";
(3,388 Views)
