calling dyanamic events for boolean control with mechanial latch action.
           I have two boolean controls one does write operation and other does read operation. what i want is when i trigger a write operation after it is done it should go to read case without user hitting read button. Please send with a small example and my button type is having latch mechanical action. i am using labview 8.5.
(3,590 Views)
Well...for me its not very clear what you want to do, so maybe you can post an example.
Christian
(3,568 Views)
Hey srinivas
What you want your program to do can be done using a State Machine architecture that uses an event driven user interface.
I have written you a small program that you can use by replacing the one button dialogs with the code you want to use at each stage.
I hope this helps
Philip
UK Branch
===If this fixes your problem, mark as solution!===
(3,563 Views)
Can you send me the attached program in labview 8.5 ver
(3,561 Views)
Hi christian,
                   Right now i have a code which works for 2 event  cases for write and read operation. I want to change the existing code in which after  write event case is triggered by user control should automatically trigger the Read event case without user intervention.
(3,560 Views)
Accepted by topic author srinivas
Here you are, sorry about that
Philip
UK Branch
(3,548 Views)
Thanks it works fine and i got the idea how to do it.
(3,529 Views)
